2 hours ago, spudulike said:
Worth getting a dealer to plug it in and see what the CST read out looks like. You can often read a fair bit in to what the H&L is set to.
Did you check the pump diaphragm? I have seen the pump flaps holed on high use saws.
Has the saw got decent compression? I have also seen poor compression on high hours saws but saying that, the one I have in at the moment is 371 hrs and has very decent compression.
Good compression, no piston scoring, pump diaphragm was rather hardish tbh. Like you say spud worth getting it plugged in and see what comes up. No idea on hrs you obviously have the software to read this I take it? Thanks
  • Replies 27
Yes, I have access to it....where are you in the country.....and don't take that as me wanting work but you may be just down the road!
Mid Wales, I would be able to travel or post thank you
I did have suspicions with your Christian name being Aled.....unfortunately not just down the road and have knocked the postal repairs on the head! Sorry.
Shame, trying to find someone more local if not it will be scrapped.
Is it not worth a carb kit before scrapping it? You said the diaphragm felt too hard in an earlier post, could be the problem.
I will try that first thank you
