Edit-
Just picked up new chipper. Likely loose connection sprayed oil everywhere and in my terrible mood I overreacted asking for advice on approaching dealer for fixing stuff, would rather not have this for all of arbtalk to see please mods..
Edited by Cordata
Oil sprayed on the machine will do it some good!
Take a chill pill and let the fitter find out where the oil has come from. Assuming hydraulic, might have just been a loose fitting?
Hope the driveway is ok?.....
Edited by scbk
Apart from the belts I wouldn't worry about spilt oil. Every machine is going to have a burst pipe at some point and it won't do any harm.
The dealer/manufacturer should get it repaired but the first thing I would do is open it up and check if it's just a loose pipe. It would have to be a major failure that is likely to repeat to get a replacement machine I think.
If it’s hydraulic oil (most likely) it’s likely a poorly done up pipe that QC failed to pick up.
Not the end of the world.
What model Först is it?
  • Haha 8
Think it will just be a loose connection, and following these replies I realise I probably look like a bit of an idiot getting worked up about some oil..
Don't know the specific qualities of hydraulic oil to know if it's going to muck anything up, googling now seems to say not really..
I understand why you feel perturbed.
Your pride and joy, something you’ve gone in debt for, that heralds a new start, let you down on its big opening night.
Hopefully just a hiccup.
Edited by Mick Dempsey
Put very nicely and hit the nail on the head I think.
Edited by Cordata
Nice response. Things happen unfortunately,  and it never happens where it doesn't matter! Good luck going forwards and never panic!
