Only used it once. Device itself should be every bit as good as the zigzag I suppose, but it was let down by being supplied with a rope which was too stiff/thick for it to function smoothly. Not sure if you can buy it in its own?
If you can wait Notch are bringing out a CE marked Glide. Had a feel of the US version on Saturday. Seems to be very smooth, easy to use and compatible with steel core lines.
Read more
