Square tooth sharpening
Mick Dempsey
Hello! New guy from Finland here.
If you want to try square filing without the correct file then a flat file with a rounded edge is your best bet. That type of file also works on semi chisel because of the rounded edge. It's just a bit harder to position the file on semi since you have no corner to aim at. In some parts of the world those files are called goofy files.
Can I post a YouTube link? Here's an example:
On 26/04/2023 at 07:55, Dan Maynard said:
I was poking around forums thinking about files and found this page from a 1994 catalog, one of the files shown is a triangular one like the one you used. They do seem to be about a third of the price of the special 'square filing' ones from vallorbe.20201122_115058.jpg.a605ffe2ba4bffb739e6e37ea0570de3.jpg
I’ve been experimenting a bit, lessening the angle of attack with good results.
I’ll do some timing videos against a new chain when I get the chance.
