Weird ms170 issue
Sagaris650
I’ve got a problem with my ms170. It doesn’t idle very well all the time but when I manage to get it to it will die when I pull the trigger while I’m holding it. The weird thing is if I pull the trigger while it’s on the floor it revs fine.
what would cause it to work properly when it’s on solid ground opposed to holding it in the air? When I hold it I have it in the exact position as it is when it’s on The floor as well.
I’ve put on a brand new carb, air/fuel filter, using brand new aspen fuel and a brand new spark plug. The only thing I’ve noticed about the spark plug is half of it is brown and the other half is black.
Does it sound like I need new crank seals?
Thanks James
AV mounts flexing and affecting the throttle linkage?
Strange mechanical things can happen; I had a saw on which the choke would only engage if it was held vertical, problem was a loose choke butterfly screw letting the butterfly drop and jam against the carburetor when horizontal.
I was thinking a mount or a vibration issue. I don’t think it’s a throttle issue because the carb opens and closes fine on the floor or in the air. The saw is struggling to rev like it’s a fuel or air problem but I don’t get why revving the saw on the floor works opposed to when I’m holding it in the air.
Could be split fuel line or intake boot that stretches slightly when the saw is moved on its AV .
6 hours ago, Sagaris650 said:
I think I might of found the problem. I stripped the saw down and the rubber part that connects the carb to the engine had a bent bit f tube where it’s meant to go to the carb for fuel suction.
That intake boot might be split because of that .
