6 minutes ago, woody paul said:
I can log into Agco parts and it lists the wheels and tyres you have fitted and it's got in brackets after MOD.
That's interesting, thanks Paul.
They do fit in a high cube container on those little wheels. I wonder if that has anything to do with it? Either that or the low height reduces the chances of having the beacon shot off the roof?
Why not ask woody to get the agco part numbers for the 24 & 34" rims.
You can then price it up from kramp ?.
Then atleast you'll know if the dealers are on par price wise.
Edited by GarethM
I'm proper intrigued to know the reason too, could it be to fit in a container, or to clear under an aircraft wing, or to fit in a chinook/Hercules? . Could be all of the above, get flown into a battle zone, prepare a landing strip for the heavies and then be useful around the place.
I bet it's pleased where it's landed for it's civilian role 😉
That's a good idea!
Are you able and willing to do the honours Paul?
You never know when you might need to do a bit of 'low profile' ploughing behind enemy lines!
What I've found is; 14X34 FIXED V33123800.  11x24 FIXED V33123900 13X24 FIXED V3312400.
The  rim picture you post has long number which match's part number.
Have you tried Agri-linc
Edited by woody paul
