Arbtrak 190 - Unfortunately again, rubber clutch for hydraulic drive broken
3 hours ago, Jase hutch said:
This is OK if you can remove the sheared pins ?
If you cannot remove them without damaging the threads in the green plate, get a machine shop to drill and tap two more corresponding holes un it 120 degrees round, whilst at it might as well do 4 ready for when it fails again.
Finally found some time to unmount the assembly. I was not aware the 8 screws would hold the complete v-belt wheels, actually it's one big piece of metal. From the drawings it looked more like at least two parts, but that's okay for me. It looks doable for me to remove the threads inside or if that fails, will get 2/4 new holes prepared from our local mechanics workshop.
@jase: So I would need the two pins and a set of mikipulleys. Back in 2021, when the miki's also broke, you posted a different spare numbers for them,
P900990015 Clutch end rubber.
P900990016 Engine end rubber.
Just to verify I'll get the right parts, as you posted "TC204921/2" in your recent mail.
How can I get the parts shipped to Spain, I would like to order this week?
Thanks!
Soeren
Ok, I'll order locally then. But I still need the part number for the two pins ,-) I suppose they can be ordered on their own?
Thanks,
Soeren
They aren't available separately as far as I'm aware but I have a couple here that I'm happy to send if they ask on the order...👍
Jase.
Top man 👍
Jase.
Hi Jase,
one thing about the country here I don't like is that simple things can take ages for no reason....however, I just received a call that after one week they finally confirmed the part numbers are correct and placed the order. So hopefully you see the order coming in from Riversa quite soon.
Thanks for adding the pins! Best, Sören
  • 3 weeks later...
