I think the machine in question is a sasmo chipper which works by means of a cork screw blade which has a built up weld the machine will not have feed rollers as the spiral blade pulls it in,very good for cord wood but thorn apple etc would need a lot of snedding prior to chipping also the sharpening has to be spot on and the correct angle.
Yes I would say Sasmo.
They make chip the size of big lumps of coal, you can shovel it onto your fire.
The one I tried had no blade, the screw cut most of the way though and then a lump of steel on the flywheel batted the end off.
I only know of two makes of "screw" chipper, Sasmo and Laimet. They absorb horsepower and make big chips which they use in Scandinavia for both biofuel and cattle bedding.
