Sprocket issues?
Ledburyjosh
I have noticed that my chain is going tight and loose as I rotate it.
It happens on multiple chains and bars on the same engine unit. So can say its the sprocket end being the issue. It also oil's fine and had some new pin bearings in today.
I've had this before due to a worn sprocket .
This time though the sprocket is pretty new. So I would have expected this.
I shall replace it anyway to be sure. But not until next week now.
So in the mean time does anyone have any suggestions of what to check? Could the drive shaft be out? And if so could that be checked?
Thanks
Cranks not rotating though when youre pulling the chain round by hand.
Points to eccentricity in the clutch housing or rim sprocket. Or the interface between the two - the rim sprocket is a loose fit on the clutch so it will 'walk' around on the drive teeth as the chain is pulled round by hand (probably locks up in one position when the engine is turning it over at speed).
I have come to the same conclusion. A new rim sprocket was fitted today and the issue still persists. So the next and last thing to change will be the bit the rim sprocket goes on.. unsure of the name of that bit.
Hopefully that's the fix.
Odd as it's been on for a while, I can't see what would cause it to change shape slightly.
Either way if I replace that then it would have had new clutch bearing and sprocket kit. Which doesn't leave much else...
2 hours ago, Dan Maynard said:
Is it a big change or just a bit? Some variation is natural, the sprockets aren't precision components.
There is a chance you're seeing the problem because you started looking for it.
I started looking for at as recently my saw has started getting stuck in cuts, particularly angled cuts on gobs. Which is has not done before and my sharpening is always consistent with guides etc.
The slackening of the chain would explain this.
Nonetheless I shall stick the chain back on and get a picture to get some more opinions and input
