Propping a Yew
scotspine1
I have decided to put props on this Yew to stop stem failure. It needs 3 props. I was thinking of using some kind of treated wood like telegraph poles/straining posts but smaller diameter. Going to sit the poles on concrete slabs embedded under the grass so they won't be visible on the lawn.
Anyone done any propping or got any ideas about what wood to use for the props?
How do you make sure the props stay attached to the stems during high winds?
  • Replies 50
Mebbe attach them with fabric straps?
NO! Fabric straps will cause mucho cambium damage...
I had to install many of svensk tradvards padded cable braces in the '90's, and do checks on old ones. the amount of cambium damage from the fabric was horrendous.
Far better to cross bolt than have any kind of padding pressing on the cambium.
Pecon,
The original idea was to cable using Cobra, but I decided that the angle was wrong for cabling, poor angles wouldn't allow for any increase in structural stability/strength.
There has been end weight taken off the stems already, long term to the plan is to encourage the juvenile growth around the main trunk to slowly replace these large stems. But for the moment, the large stems are needed for feeding.
Ed, are you saying to drill holes to hold the yoke/support in place? That might work, they dont have to be too big.
