Thor Alpino or Mignon
Matt Venn
Looking at the above two splitters for doing around 10m3 a year. Is the 11t Mignon worth having over the 8.5t Alpino? Think for the bulk of my splitting 8.5t would do the job but for the extra £500 would the Mignon last longer as a heavier duty build, I’m planning this splitter doing 20-25yrs for me. Both would be 230v electric motor, and if I ever need to use it away from the workshop it would be powered off a genny.
I don't know either splitter sorry, but you'd need a hell of a genny to run one!
Even on the mains, for 3kw working away for hours, you need to have a decent electric connection.
The less powerful splitter has a slightly smaller motor and slightly higher speed.
And 110kg vs 171kg.
That means a load more metal in the bigger splitter, but a lot more effort if you want to drag it about by hand!
I had a petrol Mignon and found it a great machine once it was going.  But it was a pig to move anywhere - it had next to no ground clearance so unless you move it on good flat concrete it's a real pain to get anywhere and heavy with it.  Very good as a static machine though; I loved the foot pedal function for gripping logs with the blade
6 hours ago, daveindales said:
I've had the Thor Alpini 8.5 ton for 3 or 4 years now. No problems at all with it
Have you been happy with it? I’ve looked at them all and it was between Posch, AMR and Thor and I think for the price Thor look good and I like the idea of the foot pedal and auto return.
The Mignon I can spec with big pneumatic tyres which I think will help the ground clearance problem the little plastic ones on the Alpino look a bit flimsy to me and I’m sure will be the first bit to fail.
1 hour ago, nepia said:
...which would have left the machine on the tilt when working surely unless you went to the trouble of chocking it?
I think they go on an axle modification bracket that moves the wheel higher than it’s original position. This means the machine sits level when in use. Off memory I think they are 40cm diameter
23 hours ago, Matt Venn said:
Yes, more than happy with it.
  • 3 weeks later...
