by 'adding' choke you are adding fuel, so manually overcompensating for a weak oil/fuel ratio. So, yes quite possibly an air leak.
Same situation with machines that have been left for sometime with old mix in the system. Will start on choke- stalls as choke comes off. Indicates a 'blockage' in the carb, so enrichening artificially with the choke will overcome it
Edited by pleasant
On 13/01/2023 at 09:41, M4cc4s said:
thanks, so am i looking around where the carb is seated
Maybe, or crank seals. It wants a pressure/vacuum test ideally, then you know if that's what you are looking for.
  • 2 months later...
55 minutes ago, jonconner said:
Most Common stihl ms 271 problems are
hard to start
smoking
bad ignition
chain brake issue
stalls
Mmmm . I have heard that people can break their leg when they fall over .
Edited by Stubby
