Ifor Williams tipper problem
33bk
1 hour ago, 33bk said:
I’ve got a ifor William tt3017
I had a problem with it and thought it would be the solenoid but it’s not it’s got a full battery and in the video it’s on the truck charging
I really don’t fancy pumping by hand got a lot of work todo with it !
IMG_3420.MOV
Sounds like the a similar problem I had, where I had to undo the valve to lower it manually once, and I hadnt done it back up, so pump sounded like it was working, but it was pumping back to tank. Have you checked if it's done up?
Or is lowering solenoid jammed open?
IMG_3420.MOV
Have been here before I had one of those remote controllers as in your Vid they were fine and yours seems OK when working, but the main problem we had with intermitent working ( which is a real drag with a full load of chip at the end of the day) after changing the solenoid then battery was infact the battery terminal lead connectors and or the conections to the pump unit they can corrode up badly only found this by chance as they were sparking in dusk light, hope this helps
it doesn't sound the same as mine did when it stopped working but it turned out to be a faulty remote unit, the actual black box bit that plugs in. sent me a new one and sorted it.
it was just cutting out every 2 seconds u pushed the button
anyone who hasn't got a remote is an idiot 🙃
