Hey up folks, i thought this is worth a share. Ive always found it difficult to secure loads within the trailer, without butting up against the headboard or ladder rack. Particularly with an IW LM106 @6ft 6
If theres no gap under the dropside it gets a bit tricky and at best it’s a juggling act. My old ifor eurolight was great as your could close the dropside with a strap hook under the edge of the bed. That annoying lip on Ifors is a serious pain.
Got an IforWill TIpper105 as my ‘forever trailer’😀so been thinking about this for while, a beam or bracket which locks in to the shape of the bed without any adjustment which would affect resale value.
I also wanted something which speeded up loading as strapping the cs100 can be a nightmare with no load loops and its a crying shame if the powder coat gets scratched. I only do a few jobs so chipper cant stay loaded. Options were either a bracket the chipper rolls/slots into or a custom set of hold downs for a single strap.
Finally got a bit of time to make this beam and its mostly geared towards a wee chipper in my case Greenmech CS100.
So basic principle is fitting the beam ends into the dropside midway posts. Channel section i used is 2mm folded from an industrial greenhouse scrap i picked up years ago. Then an 8mm hole though the trailer post drilled through to retain the beam against the floor so it doesn’t skip out over the 50x30 section which goes into the bed pocket.
Took off galvanising with distilled vinegar from tesco 29p a pint, took two days. Welding galv is terrible and harmful so well worth this step on thin sections to avoid grinding and losing material.
Using material which has enough depth to act as a solid wheel chock then a single strap holds it rock solid against the chock and tyres take up the tightening straps nicely. Only area i’ll have to watch is the belt cover which the strap rides against. May think about domething to deflect that?
Your probably be best using 50/50box as 50mm is the dimension of the trailer post so easy to pick up with side plates welded or bolted to make an easier task for DIY, I used channel as i needed access to back of it and before adding the flatbar the 50/50 option seemed like over kill.
I struggled for a while to come up with the tie down points method as this channel is 80mm wide but floor cargo loops don't fit. In the end i drilled some 4mm thick by 40mm flat bar with 12mm holes to accept M12 eye bolts and picked these up against the channel after transfering pilot holes. Eventually i’ll weld on nuts to the mild steel bar but not sure its finalised yet and worried about holes if i galvanise it. Currently just fixed in with M12 nuts which works but adjustment is a little awkward.
This beam will also be a future anchor point for a load/chip partition able to be adjusted so i put a load of holes in to allow different sizes which will match a bar i add to the ladder rack if i go that far.
Future points will be a winch as tipper bed is quite high and 8ft ramps is a struggle pushing, so i can use shorter homemade ramps as current ones are an absolute ton (60-65 kg each).
Getting hollow plank extended sides sorted as money comes in😮💨
Btw, cost so far is zero bought as had all this kicking round but eye bolts are literally a couple of quid if you’ve got steel kicking round its a cheap build.  And with 50 box it’d probably be fine with tech screws if you’ve no welder.
this is a great forum so more than happy to share and pointers and thoughts welcome.
ciao for now Mikey 3DC36909-8CFF-426D-99CD-BB857A140843.thumb.jpeg.80c2f6ccbae84d5173a1308797633e22.jpeg93AA2514-2B22-403C-A30C-A0341154EDEA.thumb.jpeg.d9387ab475d200cb6695a5152b374750.jpegBA4B8667-03EC-4446-B458-140ECCE767AD.thumb.jpeg.d0609aef73751cf16e6356750efad901.jpeg7BBD81EB-A2AC-4308-8F4D-E642D1C44BDA.thumb.jpeg.e89bd76e258cc4a1483bc4bd0eab9d8d.jpeg063C2D04-B515-4C5C-8BEA-CF24E71252E4.thumb.jpeg.5aee6edff8e5850a6a28fe4b140f72d6.jpegFB333DD9-53B7-4272-94F0-9032C13A11DB.thumb.jpeg.c639b1a999f9e246cfe3a86a6fe4a986.jpeg
  • Like 6
I had a job on today and chipper loads so easy its down to minutes. I have cut down a ratchet strap and when not strapped down i just hook it around the battery box no worrying about threading things through. Saves a good bit of messing.
i just need to get rid of my monster tank ramps, they weigh far too much.
Anybody know of a light weight option that fits in the ifor ramp holders? Only need to be rated to 500kg. Don’t fancy buying ifor alloy ones they’ve shot up.
cheers.
Edited by ostosix
Spelling mistake
