My clutch drum doesn't catch on what I think maybe something to do with the oil (but don't know), Should I run it or new clutch time ? Or something else? Thanks ladies and gents.
nemcc
It’s a bit hard to work out what you are actually asking, but I will give it a go.
The groove on the bell housing in your hand lines up directly with the oil worm behind the clutch which drives the oil pump.
If you shine a torch down the outside of the clutch you should see a piece of metal sticking out, locate the groove over it. If you can’t see anything sticking out, the end may have worn away/snapped off.
You will need to remove the clutch to replace the worm.
