4 hours ago, Piston Skirt said:
There’s a special procedure of carburettor adjustment for units with a little P in circle next to serial.
It has an active ignition coil that compensates ignition advancing to keep the idle steady.
To adjust the carburettor the override procedure must be done.
Mine has the "P" in a circle just like you say..
Wonder how you do the override?? Nothing about it in the ownera manual..
john..
john..
Of course it can't be in the manual :)
Current emission laws force manufacturers to do everything anti-tackle so that only authorized hands would be able to adjust anything.
Echo dealers are usually trained to do override and adjust the carburetor in 5 steps.
Just as well i never fiddled with mine then!!
john..
