Stihl 362cm carb sensor wiring loom
Mikee.B
Hi all,
A wire has come loose from the 2 pin plug at the joint that allows you to remove the carb, it's on the carb side. The wires are so short it would be difficult to replace the plug, I wondered if anybody knew if it's possible to buy separately, I can only find it attached to a new carb at 160e 🤦‍♂️
Thanks in advance.
Find out what kind of connector it is then you will probably get one for a couple of €. It looks like it might be a Molex type connector. Workshop manual shows the whole part as a trigger unit part number
1140 430 1000
CHAINSAW-WORKSHOP-MANUAL.COM
Stihl MS 362 M Tronic Chainsaw Parts Diagram
Edited by peatff
19 hours ago, Mikee.B said:
Hi all,
Thanks in advance.
Stihl Farm Boss chainsaws are very powerful. My favorite chainsaw model. I like to working with it. I have Ms271.
They are the " home owner semi pro " saws .  Slightly less powerful and slightly heavier . Not for me .
Do they look like the MS362cm or use the same carb ? They are the same colour an that's about all.
