Big auger
Mark Bolam
  • Replies 20
I've used a similar one before only up to 1.5" though...
If drilling deep holes it's a good idea to take the drill bit out and cool it every now and again to stop it losing it's hardness ;)
Also, don't force it! The bits can shear off if you over work the drill...
Also if the holes a little "rough round the edges" it would look better IMHO...
have you guys seem the site 'rack and ruin' ? the expansive bit is ok but you'll struggle with a hole big enough for a wine bottle and doesnt run very true! have made a few rustic wine racks for friends after they saw the rack and ruin ones but couldnt afford there prise tags! is alot of work to get it right, i use an 4" hole cutter which only goes in 2" at a time but does a very neat job!
