27 minutes ago, Mick Dempsey said:
Green wheels are OK, I just hate the toxic mess everywhere.
That's why I use the bench grinder, with green wheel, inside this desktop shelf with a vacuum sucking out the back. I put a fresh piece of pallet wrap after putting the grinder inside and tear a small hole to grind through.
Teeth on the chinese machine are £11 each so worth touching up frequently.
161330473_Screenshotfrom2022-05-1818-53-09.thumb.png.74dcf8720e2bc9d70a18d30bf18de634.png
30 minutes ago, Hodge said:
Please can you tell me where you get those diamond wheels David?
Hi Hodge. If you Google " Abtec diamond wheels" you will get their website. You want the 150mm diamond wheel. It says on the order form that there are 3 grades of wheel, but they only seem to have the medium. They really are brilliant. The lady I contacted was called Michelle Rowe, email address    [email protected]
This was from a few years ago so may be out of date. You will also need to order, for free, the insert for the wheel to fit your existing bench grinder. I bought the whole set up, wheel plus grinder. Nice people to deal with. Any questions give me a bell.
Thanks David, I will look into it.[emoji120]
