Power loss with Thor Alpino 8.5 logsplitter
Richard Men
I have a quarter share in a Thor Alpino logsplitter which has been brilliant fro processing firewood for several years. Recently, it has been losing power and struggles to split an y knotty wood. I have topped up the hydraulic oil, cleaned the magnetic filter and we always make sure the splitter is used on the level. Can anyone please suggest what the fault may be?
not same splitter but had some issues with mine that made it slow
hydraulic filter was horrible so lots of slower,  a ram seal weeping, annoyingly had to get a bigger tank as original tank wasnt matched well to pump volume,, hydraulics place checked flow rate and was 19 litres a min at pump and way too small a tank so oil got hot and that kills performance
now got a 60 litre tank and doesnt matter how long i run it, how hard logs are never tops 25 celcious in summer in full sun and never drops performance
but an oil/filter change will tell you a lot as a good start
What is in/on the magnetic filter will normally tell a tale.
Bob
