Wood wanted Purfleet
Woodland_Sprite
27 minutes ago, Woodland_Sprite said:
Hi I am looking to build up a good supply of hardwood (not fussed about the type) for my pizza oven. I don't really want to pay out £90 and upwards for logs in the bags but I'm happy  to pay towards delivery/labour costs. I'm located near Lakeside Essex.
You could try adding yourself to the tip site directory but , being specific ( picky 🙂 ) about the wood type might limit the response .
Yeah, if selling logs then hardwood is what most people are going to ask for.  Hence being picky about only hardwood means you are unlikely to get much as hardwood is much less likely to be dumped.  Also the tip site is set-up for traders working outside their areas so it is also worth contacting local traders direct to see what is available (either to buy as logs or as waste product for you to process into logs)
I've been  contacting some local tree surgeons, and I've had a good response. Should be getting a load in the next 2 weeks.
