Can any one help me my chipper is starting up and cutting out when it starts chipping and the code ale I fink but it could be alt . Il try to put a pic up any one have any ideas what it could be .
Expand
@Jase hutch will know but it looks like an alternator problem and the stress control depends on the alternator to measure the rpm.
Thanks I have check the belt and that’s ok I have had it started and the belt is spinning so I think the alternator . Is working but I’m not sure I have sent that guy a message so hopefully he mite know but if any one els can help that would be great .
Or it's on top by the air filter..
It's the 20amp fuse and it's connections that need checking..
If that appears OK it may be a fuel blockage ? When was the fuel filter last changed ?
Jase.
We had that error code come up on our 150 and it was the computer screen/ computer  what had gone down. We thought it was the alternator to but we tested it and it was fine it would try and turn over but wouldn’t start the computer wasn’t letting fuel through so we ended up travelling to greenmech to get a new computer took ours with us to try it on another machine and found that it was the problem. Also had problems with the fuses popping  like the other guys are saying also had problems with the plugs what are near the computers getting damp in them that also caused faults bad connection we got in touch with greenmech and one of there technicians kindly told us what faults it could be they was very helpful. 👍 hope you get it fixed pal 👌
Edited by Patrick goulding
Read more
