Anyone help with hydraulic valve name and where I can get one please?
swinny
Can anyone help me with this please? This is supposed to be a turn dial type valve to affect the speed of flow of hydraulic oil.... specifically the sweep speed of a grinder....
The top has gone missing on this one a long while ago but I'll attach a pic of what is should be etc....
I would think it would come as a full unit and screw directly into spool block.
Any help greatly appreciated! As with all these things it's about terminology and knowing what they're called so you can search!
Cheers
Tried dealers but still nowhere 2 days on. Need pics sending in. So thought I'd post them on here.
Basically it's just a device where you turn the dial and that bottom needle lifts up or screws down.....
Shame I couldn't get this freed up to make a top and handle for it.
It's got to be a standard part as only screws into spool block
2 minutes ago, Jase hutch said:
It looks like a simple flow control valve.
Can you add dimensions to a photo ?
Is the control valve a 'bib' valve ?
I think we have the same in stock at GreenMech...
Hi Jase.... what's a bib valve please?
What do you need me to measure....?
Be handy if you do as need some gm spares too 😀
Many thanks Chris
Edited by swinny
Many thanks Chris
Nip it in to Walker hydraulics in Kiethley, not that far for you, or ring em and send them a photo and i am 99% sure they will sort it out for you, i have found them to be allways very helpful in the past, it just looks like a flow control valve to me as my forwarding trailer has em on and they wont of been moved for 10yrs + now,,
