On 04/02/2022 at 14:01, coppice cutter said:
Thanks for that.
It's for a family member so I've just been relaying the info from here on to them.
Finding a decent double-sided is turning out to be so difficult that they're even thinking of re-jigging the layout to allow them to fit a conventional stove.
It's going in to a new build.
In thst case there will also need to be an air supply laid into the stove room irrespective of the stove size.
That's correct.
The inlet's already been built in to the external wall and will be ducted across the floor.
On 07/02/2022 at 12:43, coppice cutter said:
That's correct.
Very few double sided stoves can accept direct air,   as long as there is a non closable vent in an external wall of the stove room then that is fine.
A
  • 3 weeks later...
