18 hours ago, Con said:
You're not restricting a fuel line when putting the air filter covers back on?
I think this was the problem, I removed the filter and made sure the fuel line was free did the air filter back up and checked fuel line was free and bingo. Now it runs like a dream! Thanks for all the help and suggestions, this easy fix has made my day!
well spotted con ! 👍
Strange one, is the carb held on with two small nuts on the threaded rods as it should be? I didn't reckon it was this as it would either be clamped or not and the fitting of the air filter wouldn't change that: -
Yes thats right, I found i had to do the air filter up a little bit each side until tight to get it to sit tight on the carb.
Hi guys,
Am I right in thinking the best/safest way to tune the carb is to use a tachometer to get the revs at the recommended rpm's and then the fuel air mix will be correct?
Yes, there's a procedure in the manual to follow, with a tacho.
