On 05/01/2022 at 12:41, BobbyDee said:
Just what I needed thanks. I am currently turning the engine with the pull mech removed and using an 18v cordless drill and socket. Fuel is coming through fine but there is definitely no spark. Turns out that the reason I couldn't source a replacement coil is because Echo has changed the part number to P021 037431 and it's around £100 all-in which is somewhat less than a new saw.
I think this is the coil for the Echo 4910, others have ported both saws and changed the coils over and got identical times when cutting, the coil used made no difference.
Edited by Echo
On 04/02/2022 at 16:23, ChrisNewport said:
If your stuck, ive just found a 501 under the bench which i'd forgotten about,  i was going to repair it (lean seizure) but cant be bothered. I can send you the coil if you need.
Thanks. I've messaged you.
