Just after some advice I know it’s best to keep firewood outside to season but I have a large carport with an open wing at one end with enclosed sides would my wood season ok in this or will it take a lot longer?
thanks
thanks
That sounds ok from your description . The components needed are air flow but keep rain off so , yea I would say .
Thank you I’ve attached a photo to make it a little more clear it is waterproof just the logs won’t get any sun but should get a bit of wind as always end up with a huge pile of leaves that have been blown in there.. they will be stored in IBC cages
Edited by Alex buckle
That'll be fine. Good airflow, wind is more important that sun anyway.
As said it looks nice and airy which is key. To speed up drying further stack them so air can reach side of the rows as wood loses moisture fastest through the end grain
