Should of sniffed it too, for the beeswax:biggrin:
it isnt a typical colouration and certain it is this that is leading to students being taken into epping and being told that certain trees are hosting G australe or applanatums rather than the true identity! its multi bracketed nature is also a clue, but partly due to the origional sporocarp being taken and regeneration.
the classic give away is the amorphous black clumps which are atypical of seasoned pfieferis.
australe would not be confined to the dysfunction, though pfiefferi will cause sinks in living cambium though rare and on very weak trees.
  • Replies 239
This one at Seven Sisters always makes me think.
I imagine that it's far older than it's size would have you believe.
Edited by EddieJ
  • 3 weeks later...
Nature copying man copying nature :biggrin:
That stub with the best tear was last years, the newer one is not obvious in shot.
which leads me to ponder and ask you in particular...
this spur has not produced shoots, I suspect due to a lack of light, do you find similar failure to regenerate in shady stubs?
If I get your train of thought, then I generally expect failure on a retained beech stubs in shade. particularly if they are bare stick.
Always a better scenario to fracture back a branch with existing photosynthetic capacity, preferably already in light.
Shots show at point of work & then another one a year on.
I think a lot of work needs doing on light, we need to know more about the response of cambium to certain levels of it and other stimuli.:thumbup1:
