Hey guys,
My 2013 Vermeer bc1000xl won’t start, it cranks but won’t fire. I have narrowed it down to being my fuel solenoid isn’t getting power and I have no idea why it is not. The computer is not allowing the solenoid to get 12volts for some reason. If I plug it in directly to the battery the Solenoid will open and I get fuel and she runs but if I wire it correctly the computer doesn’t send power and the solenoid stays closed and lets no fuel past. Any idea of how to fix this?
has b3.3 Cummins motor
Edited by JakeCtrees
  • 1 year later...
27 minutes ago, Adam987654 said:
Hi mate did you find out the problem because I have same problem
He made 1 post 3 years ago not been back since i do not think he will be replying any time soon.
I would put a live feed from the battery to the solenoid via a small switch and a relay. This should get you running.
add a fuse in there!
Edited by Will C
Fuse
