Any ideas? I’ve labelled the loose wire 1. Is it meant to be under a nut like the one numbered 2, that appears to be the ground cable on the parts diagram? The saw is functional so I’m assuming it can’t be *that* important?
Thanks [emoji106]
Is this a heated handle model? Just had a look at my 576xp non heated version and the only wire visible is for the stop switch which is a female spade connector,  not a ring terminal. Mine is normal carb not auto tune which may differ?
Edited by bettio
Downtown just finished, yes this is the earth return wire and should sit under the head of the rear l/h side screw, somebody must have removed the screw at some time for it to be just hanging there.
Thanks adw
Is the screw you mean the one by the clip for the casing, or the one which I’ve labelled 2?
Or no odds which way?
The one you marked with a 2.
Just wondering if this loose wire would affect the performance of the saw? Somehow it seems like a cleaner crisper saw now. Maybe it’s all in my head…
