On 19/09/2021 at 21:05, Billhook said:
I think its days of everyday winching work are long over and it is there because the D7 had one on originally and I like messing with new toys.  I would only ever need it to either pull myself out or perhaps the 15 ton JCB 806 if it became stuck.  Do not think I will every be winching trees out.  I expect it will require some effort just to pull the cable out unless I can do it with the Kawasaki Mule or a quad.
This was one of the comments after the video which has made me nervous!
Back in the 80's I was in the airborne infantry and a few of us were offered a chance to cross train in vehicle recovery. It was a three week class and I learned a lot about recovering every type of vehicle you can imagine, and in every type of situation you can imagine. The one thing that stuck out that I will NEVER forget, was seeing the damage done to an M88 tank retriever when it's main winch line broke. The main winch is a 70 TON single line pull, and I believe the cable was 1.5 inches and I think there was 300 or maybe 400 feet of it. When the line snapped, it came right back and hit the M88 head on like a punch, and it knocked a hole RIGHT THROUGH SEVERAL INCHES OF STEEL BULK HEAD. You could see where it actually melted the steel as it forced its way through. No one was hurt, but it scared the crap out of every man there. The instructor said this is what happens when you don't do the math when figuring mire factors, block and tackle friction factors, knowing real vehicle weight, and enough pulling power to winch every sick whore in the world off her piss pot at the same time. Seeing that made me even nervous to pull too hard on my boot laces when tying them up. When we winch now, my pucker factor is always so tight you couldn't pound a pin up my ass with a jackhammer. I really know what can happen and it's scary. Whether or not these tests are real world, the damage a broke wire rope will do, is real world. Keep up the great work.
Show less
Whilst appreciating the kinetic energy involved when a steel rope fails under tension, I still find it hard to credit/impossible to believe that this energy could be foccussed in such a small area such that it would melt its way throught several inches of steel. Also knowing the proclivity of soldiers to tell tall tales!
As someone said "pics, or it didnt happen".
mth
mth
Whaaat Difflock! You do no believe a story from one of her Majesty’s finest!
Next thing you will be saying you do not believe half the stories posted here from Arbtalkers!
Edited by Billhook
There could be slightly more "embellishments" to be found on the ARRSE site, but  .  .  .
P.S.
That author of that account re the 70 tonne winch rope breaking did not actually state that the author witnessed the damage, only that he saw it. Which makes me suspect it was possibly/probably the result of some anti-tank weapon, BUT the hairy arsed instructor decided to use it to impress his trainees, or perhaps test their gullibility..
Edited by difflock
