Hi all
i have and ifore tipping trailer the pump electric sound as working but won’t go up I hand pumped it . But won’t go down   Any ideas on how to fix .
Maldonado dose anyone no where I can get a solicited switch as min has been intermittent.
2 hours ago, Philbe said:
Hi all
There is a valve you can undo to get it to go down. It sounds like the solenoid has failed
4 minutes ago, Philbe said:
Hi thanks I’ll have look when I next go to where the trailer stored
It's a little finger wheel just next to the pump handle on the front of trailer.
Will most likely be seized solid if it's not been used for a while.  Good practice to lower the tipper with it once a week, just to keep it free for when it's really needed
The moto at work is use it every single time because there's always something else to get on with while it drops itself.
Hi yes that solid . Do u no where I can get spares from pump . It’s been so good but don’t get used very often . I had full load horse poo on and stopped working .
Any Ifor dealer will help, one near me are knowledgeable and very helpful.
ALANTUERTRAILERS.CO.UK
Ifor Williams Trailers for Sale: View our Full Range of Ifor Williams...
