are the nptc refresher courses compulsory?
lewis 33
On 01/08/2021 at 20:44, lewis 33 said:
i got the chain saw maintenance and aerial rescue over 10 years ago. if i wanted to progress to using a saw from a rope and harness would i have to take refresher courses first? thanks
You cant be assessed using a chainsaw in the tree if you don’t hold the felling small trees ticket.
If you have the old CS30/31 maintenance/cross cutting/felling then crack on, but if you only have the maintenance/cross cutting part you need to do the felling ticket first.
HSE state:
All chainsaw operators should do regular refresher/update training to ensure they work to industry best practice and maintain their levels of competence. The suggested intervals for refresher training are:
  • occasional users – every two to three years;
  • full-time users – every five years.
This is a suggestion. The best person to talk to is your insurer and what they expect from you so that if an incident did occur they will cover you.
