1 hour ago, adw said:
I am fairly sure you cannot grease the bearing through the end of the crank.
Ok Andrew . Was not sure as on some Huskys you can .
Saw could do with a bloody good clean sir.
Yes I know that’s how it was when I got it. Absolutely covered. Will be a lot better when I’m finished I hope.
Quick update tried tapping with soft drift no chance. Fabbed up a tool and removed clutch bearing very dry but ok. Cleaned down a bit all ready to try on Wednesday with some sycamore
Fabbed tool has poor weld as using a large rattle gun and wanted weld to fail before any damage could be done🤣🤣
