No mix in 2T machine
Jack.P
I think Gardenkit ran a strimmer on straight petrol once and I am not sure he ever made it seize. It was 2T but, because strimmers run at lower revs than saws, it lasted a surprisingly long time.
No idea on your 4T machine but I would load it up with the correct fuel and see what happens. Hopefully it will continue to work .....if you are lucky! It is a bit pointless stripping it all down if the thing is running OK and not showing any issues.
