Probably by someone nearby with a chainsaw 😋
 At a glance,  tap root decay working its way up and around through the tree' life span. No evident fungal brackets. Looks like a busy road location K
1 hour ago, Chris at eden said:
Kretz
Probably and something else from those black lines (pseudo schlerotic plates?) was entry from that bark damage showing compensatory wound occlusion at the bottom of the photo?
Kretz
Agree kretzschmaria is probably main pathogen, the black lines (pseudosclerotial plates) and lack of obvious decay evident on sounding is indicative. the wood associated with the tap root will have been "eaten" by another fungi.
Salt and the inevitable grass cutter damage won't have helped.
Looks to have occluded quite a few wounds in it's time, entry will probably have been from one of those.
