Check it’s getting full revs or the no stress will stop the rollers.
The sensor on he stop bar has been known to vibrate lose and move toward the stop bar so it thinks the bar is pushed all of the time.
the hood cover sensor can be tested by dropping a socket over it so it thinks the bonnet is shut. It’s the same side as the key (be warned doing so will mean it can run with the bonnet open so don’t stick your fingers in anything you wouldn’t stick your old chap in)
