hi everyone. i am looking to purchase a chipper that would be required large amount of work every so often, not used everyday commercially. But i want it to be easily moved around the property.
I was looking for one that had a good capacity in terms of the maximum diameter, mainly as i would be under using it mostly and then have the capacity when needed HC15 or an HC15 Pro. Has anyone got one and can compare it to other models? is there anything else that you would recommend?
HC15 Ihttps://www.cheapmowers.com/acatalog/Lumag-RAMBO-HC15-120mm-Professional-Petrol-Wood-Chipper-LMRAMBOHC15.html
HC15 PRO https://www.lumag-gb.co.uk/shop/lumag-rambo-hc15pro-150mm-petrol-wood-chipper/
Edited by Ashley MK Maintenance
wanted to add a question
This:
 More or less the same Chinesium machine for very much less.
This one sold from Italy.
If you visit my business FB page and scroll to 15th Oct there is a video of it in use.
Although I can call upon two CS100s when required, I bought this for a specific job in a hard to access garden in Dinan which I did with my wife.
The negative points are an infeed 11cm narrower than the CS100 so even more snedding.
A few protruding bolts potentially slowing the flow.
Noisier than a CS100
Rubber gasket between chute and cassette and infeed and cassette deforms under pressure slowing flow and causing blockages. Sorted by removing and no ill effects.
Security on opening infeed needs removing and replacing with a simple nut and bolt.
My verdict is that is is excellent value as an occassional use machine.
Knives are cheap at €63 a pair and hold up well enough.
In France, the CS100 is sold for over 5 times the price at €8k
Stuart
WWW.AGRIEURO.FR
Broyeur de branches thermique GeoTech PCS 155LE moteur...
I wouldn't buy anything again from AgriEuro, have been waiting two weeks for delivery, tracking is a joke and Dacsher who they use are appalling. Supposed to have been delivered today lots of messing about whether it was on truck or not assured it was  definitely on the lorry. Now find out was on lorry without tailift despite being requested all the way along. Claiming delivery refused due to no pump truck, nobody been near the place, no phone calls nothing. Complete waste of a day and loss of earnings.
  • Sad 1
Well, that is your experience and not mine.
Shipped from Italy within 4 days of ordering.
The spare blades and bolts I ordered afterwards arrived equally smoothly.
Clearly the issue is with the U.K delivery company and not the supplier.
  Stuart
No AgriEuro have admitted they were very slow to ship and delay was not acceptable. Compounded by British arm of Dachser who are the multinational couriers used by AgriEuro. They weren't slow in taking my money though. I just hope it's all OK when it finally arrives. Glad you had a good experience with them.
Containers I think, Roro seems ok. Actually when it finally got shipped ttook 3 days from Bologna to Northampton which is impressive. The problem was the delayed shipment then Northampton depot screwing it up. Hopefully I'll be a happy bunny on Monday.
