22 minutes ago, Chipperclown said:
Hi Does anyone have and use an avant log processor, if so are they worth it and how do they compare with the more know log processors.  I have had a quote of 6K plus for this attachment?
Ta
Yes, I have one. I brought it without the conveyor  and instantly regretted it. I then fitted an old eliet conveyor to it.
I would say you need at least a 5 series machine to run it.
It's good, although I have bent the knife once or twice on some knotty stuff that ends up going to one side of it and pushing it over.
But overall, it's a great bit of kit. Made by Japa
My one uses hydraulic fluid as chain lube, the new ones have a dedicated chain oil tank
There seems to be two different machines there. The guy splitting into the trailer seems to have taken a bit of guarding off.
Probably similar specs to the japa 305 machine then.
