560xp not starting, spark OK
mirecc
Hello,
my 560xp suddenly stopped working. Worked fine other day and today won't even puff. First I have checked plug for spark and it's OK. Problem is that plug is still dry after most vigorous pulling session I have ever done on a saw. Tank->Carb pipes seem OK, fuel is getting into carb. I take it that it have something to do with auto-tune valve. Never serviced one of these newer units, don't know if its possible without diag tools. Anything else comes to mind that I can try to do myself before I take it to shop? Warranty period is long gone.
Thanks for possible advice.
If you dribble a little fuel into the carb/combustion chamber or you give it a TINY squirt of easy start does it fire in choke? If it's not firing at all with you manually adding fuel and you have spark then I would say to check the compression. If it's firing when you manually add some fuel then its definitely the carb
Whats the compression like? Sounds like it has gone pop. These machines seem to knock their pistons out pretty early on. Take the muffler off and take a look up the exhaust port and bring the piston up so you can see the ring and skirt - it may have some scoring on it.
These machines also don't show a lot of fuel on the plug, a seizure can cause a dry plug as can a BIG air leak but am not going to go in to the technicalities as to why!
Compression seems good, measured it earlier today. I have squirted a bit of fuel into intake with syringe and it fired right up, for few seconds anyway. So it's probably carb. I ll take it to shop for diagnostics.
Edited by mirecc
Good news, so you have compression/spark/timing etc. I know there's an update kit for the 560 as they had issues with not starting after re-fuelling. Something to do with breather lines, replacing the breather and blanking off a vent into the crankcase and it's available as a kit. There's also an "update" from the dealership for the computer too
By refuelling you mean running tank dry and then adding fuel? I topped like a half tank in the morning and it never fired since then.
I'm not sure of what they mean by "refuelling" I'm not a husky tech. I just know that it was a common fault and there was a tech notice with the 560xp's. Failing to start after refuelling was the notice and they bought out a kit and ECU update to fix it
