If its just milling you are looking to use the saw for then I would go for the MS661. we have always used the 880 for milling and have stepped it up for a double ended mill with 880 each end. if your able to pick up a used 880 you wont regret having that extra power. What size timber you looking at milling?
1 hour ago, Stihl123 said:
it was a guy from Greece that does loads of testing on all sorts of stuff, was on a lowpro set up
You said the 500i has not been designed as a Milling Saw. Is any saw designed as a Milling Saw?
well, the 880 :D
logosol used to be owned by stihl, and they recommended the 660/ 661 i believe
main man @Rough Hewn will confirm but think thats correct
