Is this the right area for this post?
I've neglected proper care over my hedge cutter the grease cap came out which meant the shaft was free to slide out it had slipped out and is now bent.
Could have a go at banging it flat or get a replacement, recommendations for a decent price not rip off!
I like these kombies, it been a good unit. Using pole saw and extension, the strimmer and small blower attachments.
for hedge cutting think I really need a fixed for purpose machine. Possibly going to try echo and not a fourmix? Want faster running.
Kombi Drive shafts come up on eBay used fairly regularly, is it the motor shaft or cutter shaft? The motor shaft on my km 90 was a bit awkward but that was all had to hear the collar to get it off and then fit a new plastic end cap you can buy genuine stihl or none genuine from LS engineer I think
WWW.LSENGINEERS.CO.UK
Drive shaft 885mm Genuine Stihl Part OEM Part No. 4140 710 3225 Suitable for the following Stihl Machines: FH-KM, HL-KM, FS-KM, FS 83, FS 83 T, SP 90, SP 90 T, FCB-KM...
Edited by HDAV
Pretty sure stihl hl series hedge cutters are two mix, and available in a faster reciprocating ‘trimmer’ (T rather than R) variant.
Just go to L&S with the correct machine type and if not in stock, they will get it in. If you open an account, they have online parts diagrams and you can phone to get a rough ETA on the part if not in stock. They mainly do OEM kit and a small bit of aftermarket.
