You won’t go far wrong with ozmo polyx oil.
To get everything to match exactly you would be better doing it all if it’s from a big supplier it’s probably got some sort of sprayed on varnish/polyurethane.
They age a bit over time so it will probably look a bit different.
  • 2 months later...
On 06/11/2020 at 08:20, DanIel Kellaway said:
I tried sanding it and treating using tung oil. It has had a nice finish but requires regular treatment. Is osmo oil harder wearing with the same type of finish on oak?
Osmo is what I coated my kitchen worktop I installed in my house in Norway, very popular for that and you can get a more harder wearing version for floors I believe?
It lasts quite a while but dont do what the folk renting the house off of me did and that was use it as a chopping board. :/ They cut right through to the wood and water etc got in. Its an easy fix though, sand back and recoat. As a coffee table the Osmo Hardwax would be perfect, it can take some abuse.
Still, my go-to is still Danish Oil. (I should get shares in that stuff. :D )
  • 1 month later...
Go for sanding with a smaller grit and then apply a single coat of wood preservative. Then apply 3-5 coat of Morrells Tung Oil. Avoid direct sunlight or heat from your oak table. Keep it moisturized and it will be as it is for a longer period. Cheers
