Hi guys,
I am new to this forum but thought I would post up a couple of photos of my first slab project - a two person desk for the study.
Desk is made out of a well seasoned piece of sycamore that I planed flat with a Record No8 plane ( a bit of a beast to use!), filled the surface inperfections with a small amount of clear resin and then finished it with an orbital sander and two coats of Fiddes Hard Wax Oil.
I would welcome any feedback or comments.
Planing
Sanding
Casting resin
Finishing
2 minutes ago, Will C said:
I think sycamore is a very under rated timber.
Looks very smart.
I think its partially because Sycamore grows like weeds. :D Its everywhere and quite invasive. But if we where to sell it as Maple it loses that negative connotation.
Looking good, presume the pencil wave lines in 2nd pic .are to show where the sander has hit?
i always think sycamore is a very clean looking wood, good to see something creative getting done with it, as it makes a great log burner wood.
That is right, I think at that point I was down on the 80 grit and wanting to identify any low spots I still needed to tackle with the plane.
I have also used it with good effect when going up the grits, if you keep an even pressure when your marking it it helps ensure you are taking off a similar amount across the whole piece.
15 hours ago, harvey b davison said:
Very nicely done. Must be gluten for punishment using a no 8 on that, wouldn't a router sled be easier. Good job, all the same.
Its a fair point! A router sled would be a much easier way of doing it but i dont have an appropriate flattening bit... i will be buying one if i do another slab project though!!
