1 hour ago, slim reaper said:
I haven't had a good experience with ELH but won't go into that. The elephant trunk  is similar but less cumbersome and nearly a hundred quid cheaper but doesn't take all the weight of bigger chainsaw pole saws.
I live in a rural area where after trying it ,several of my bemused neighbours have bought one after trying mine.
I bought an ELH years ago when it first came out . Had both dampers with it for different weights but alas I could not get on with it .
Here's the Husqvarna 535irx with the Oregon 3 tooth mulching blade (3mm thick)
I didn't have a tripod with me, the camera was just resting on the van, I was also cutting gorse and broom with it later on.
The guard is the grass guard, which gets in the way slightly, I didn't have the blade guard with me.
You did not do much mulching . Just laid it down .
It's only really the paths there that need mulched right down. Mulch/shredder blade works better than a plain one for that material as it has more "bite"
Thanks to those who have continued to reply.  An update, the 2 arm oregon mulching blade works fine, in fact works very well!
Edited by Rydal
wrong word
16 minutes ago, Stere said:
Ever tried  a saw blade for  scrub regrowth on it?
WWW.SAM-TURNER.CO.UK
Husqvarna Brushcutter Accessories available from Sam Turner & Sons | Husqvarna Brushcutter Saw Blade Scarlett...
Yes it comes as standard with the 200mm clearing saw blade, it works really well. I had a job a couple of weeks ago cutting gorse and broom away from a wire fenceline, I was using it alongside the husky battery chainsaw. A days work and not one drop of petrol used, only diesel to get to the site! Fresh air :bandit:
