I see that Honda have brought out a new 4 stroke strimmer, with a bigger engine, and this time with an anti-vibe handle (can't see the actual vibration levels anywhere though)
WWW.HUGHIEWILLETT.CO.UK
Brushcutter Honda UMK 450 XE with Honda 4-stroke mini engine with lower consumption, noise and emissions. Clean...
Has anyone used one/got one? It would mainly be for running a mulching blade.
Used to have the 35cc honda and it was great for running a blade, better than 2 strokes. It didn't have the anti vibe handle though.
Makita one is 43cc vs 48cc, with about £100 price difference, so much and such the same.
The Honda is 9kg
I tried phoning up Honda themselves to ask about the vibration figures, a phone number from Bulgaria called back, he's going to try and find out and maybe get back to me next week :vollkommenauf:
Honda spec:
ENGINES.HONDA.COM
The Honda GX50 Mini 4-Stroke Engine is one of the world's smallest 4-stroke engines. The GX50 small engine is...
Net Power Output* 2.0 HP (1.47 kW) @ 7,000 rpm
9kg
Makita mm4
1.5kw
8.7kg
2.1 m/s
Still honda may be better quality but can't really find much feedback on either.
Some reviews on smaller models:
OPEREVIEWS.COM
The HTT35STLA Honda 4 stroke trimmer features some solid torque and performance, but at $379, can it justify its own...
OPEREVIEWS.COM
The Makita EM2650LH 4-Stroke String Trimmer features innovation that offers the benefits of 4-stroke engine...
Don't get why they reckon the  honda GX35 heavy on fuel  I thought 4 stroke were suppose to used less
Edited by Stere
Yes the GX35 I had just sipped petrol. Probably seems worse as it only has a small tank.
It's now been replaced by a husky 535 battery machine which is quite good on fuel :drunk:
After more searching, managed to find the online manual for the Honda UMK450
The bottom one, XEET, is the model with the anti vibe handlebars
If its anything like the old 4stroke one we have on the estate it will be a good bit of kit ours is 20 yrs old and still going well it has a harnes that is ace for holding the weight so like I said if its as good or better than the old one we have its totaly worth getting
Compared to  to the big huskys eg 555RXT alot lower kW for 4 strokes  for similar weight.
Product Specification 555RXT
Brand Husqvarna
Fuel Type Petrol - 2 stroke
Engine Displacement 53.3cc
Engine Power Output 2.8kW (3.75hp)
Starting System Recoil with SmartStart
Fuel Tank Capacity 1.1 Litre
Line Head Included T45X M12
Handle Type Bike Handle
Blade Included Husqvarna multi blade 350mm - 3 tooth
Harness Included Husqvarna Balance XT
Vibration Levels 1.5 / 1.6m/s² (front / rear)
Noise Levels 121dB(A)
Weight 9.2kg
Power Type Petrol
Warranty 2 Years*
Got the Honda UMK 450 XE yesterday, appears to be a nice smooth strimmer. Seems ideal for running a blade.
The head that comes on it is a large Sugihara, which you reload with it on the machine, feed through the eyelets then wind it round, and it takes 3.3mm square line no bother.
It will get put to some proper work next week.
Edited by scbk
