I will replace parts 1-6 with a new 21BPX chain and 15inch bar.
That should keep me going till winter when stubby will port the saw for me.
New retirement job Stubby [emoji6] go you! [emoji16]
Don't forget in rim sprockets there are small and large sized Rim sprockets(346 is small)Number 5 needs reg greasing.
To get clutch off something like a punch or smallish cold chisel theres the ones that end with a small flat tip or chisel with a blunt/flat on it.On face of clutch theres a recess says Off by it place chosen object in/around recess and a smart whack on it with hammer to the right/forward undoes it.
Often esp if not sure on history or if worn/bearing dry! to replace Bearing.Rim sprocket and Drum as a kit in one As often because need to remove clutch as outboard the bearing don't see much grease!
6 hours ago, AngrySquirrel said:
Only "Port" with Stubby i think it would get is from a Bottle!?
Think you mean @spudulike Hes the Brum Brum man
Does anything else need greasing besides number 5?
Maybe your Nuts?.Rake bar clean if using old one.in Sharpening kit there is a tool for it but something that will run down slot in bar will do as need to clean old saw dust n crap out of there plus can clean n grease sprocket on end of bar if has a G port?
I clean/rake out round end of groove and sprocket gap as bits get wedged in there moving sprocket back n forth till looks clear heavy oil in there helps bearing if no grease port.
to check bar specs re gauge n pitch should be stamped just outside where fixing point is.
clean air filter!
