Are there better processors out there . We had a Hakki pilki but found anything shorter than 10 inch fell into the splitting chamber on end . We need to process for a kindlet so only have about 20 mm of le way . Thinking maybe Dalen or preferably something with a petrol engine
Something like a posch where the log rolls into the split chamber or the uniforest titan that has a flipper that transfers the log to the chamber.
Any machine that drops the log into the chamber runs the risk of it not landing square with a short log.
Ah 6" long not diameter.
My other reply was re diameter.
But again re tipping, does it matter if you are just ringing up?
Smallest I do tends to be 7-8" Dont have issues with that & as I said the machine has a catch plate so you can square drop them.
10 inch diameter logs are ok but need to be less than 6 inch to go under the fingers in the kindlet. So the ideal log is 6 inch by 6 inch
But why does it matter if it falls right if you are not splitting it?
This is the exact reason we’re looking at the japa 305 as the wood can be up to 11.5 inch drop in to the chamber and split into 2 or 4 then go through the kindlet ?
as most people are saying anything smaller than 6 inch the knife can be removed and it doesn’t matter how it falls
it when it falls and your splitting it it’s got to be precise
