Just had it  apart & found part : 042   519522-4  rotor assembly  is loose where its shaft meshes with cogs on 054  on gearbox
Must be knackered somehow ?
https://www.icmsmakita.eu/cms/custom/uk/parts_drawing/DUH601.pdf
Seems 2   versions of same part might suggests had issues with it so was upgraded:
Part pic on aliexpress:
Edited by Stere
The 695ZZ Bearing is completely knackered metal swarf and balls all over thet place other parts all look ok...
Wonder why that happened?
So need new a  695ZZ bearing race any brands worth going for quality wise?
Edited by Stere
Any bearing/electric motor experts?
Being looking up about bearings specs seems very complicated to understand all the codes best just to stick with the official part listed?
https://www.partshopdirect.co.uk/makita-ball-bearing-608zzcnm2a-bur18-p211032-4/
Or can swap out with a eqivalent? (Might be  an upgrade in quality if SKF etc?)
608ZZ is the one needed at the  gearbox end of the armature (not 695zz that was ok)
Vital  also to clean all grease from gearbox as has metal swarf may be balls hidden in it?
Edited by Stere
Personally I'd be very happy with the SKF from simplybearings, will be good quality. Whether that's better probably depends on the shipping cost more.
What about changing the 695 anyway when it's apart?
I think it is just a bearing, if you have the 608 code then it's the right size and type (deep groove etc) and then Z for metal seals.
Thanks  gonna try this one a few quid more supposedly extra "good".
E2.608-2Z/C3
Quote
SKF E2 Energy Efficient Bearings
SKF E2 Energy Efficient Bearings are deep-groove, shielded, ultra-low friction bearings that feature an optimised design, balanced between internal geometry, grease and cage type.
With 30 to 50% lower friction when compared with standard SKF bearings, the energy savings achievable when using SKF Energy Efficient Bearings are substantial, and the bearing life is extended significantly - in most cases more than double.
SKF E2 Energy Efficient Bearings offer ultra-low friction and typically generate less heat and can operate at higher speeds than ISO or SKF Explorer Bearings.
Dimensionally fully-compatible with standard bearings
Typical applications for SKF Energy Efficient Bearings include:
Electric motors up to 37kW (50HP)
Light to medium-loaded machines with shaft diameters up to 60mm
Excellent drop-in replacement for in-service electric motors
Edited by Stere
On 08/07/2020 at 12:31, Stere said:
Well its working again ok so far with the new bearings fitted will see if it holds up.
That's good then . ☺️
