Hi I have a 2017 stihl 201tc, bought with a broken air filter cover, have replaced this and put air filter all back in, the saw now struggles to start or run.
Any advice or tips on what to look at next
I’ve got the same saw. Maybe a bit older. Had similar problems with it. Ended up putting it in to greens in Hadleigh, Suffolk. They said Stihl did a subsidised kit consisting of new carb, flywheel and ignition module which they fitted. It’s run fine since. Hope this helps
When I purchased was running but would stall ... had no air filter or air filter housing.
purchased and fitted these and now cannot get to run, keeps stalling after starting.
not sure if it is Mtronic how do I find this?
I think 201 tc-m is m tronic and tc isnt. Might be wrong though. If it had a carb h and l jet adjust itll be non electronic carb. It check they are on factory settings and try running it. Obvs check the fuel filter isnt totally clogged as well
